Hi,
This may be interesting for those running Heltec V4’s.
Also be aware that firmware v 1.13.0 fixes some issues on the Heltec V4 with regards to the “deaf” Rx issues but apparently also introduced a bug with regards to low power management.
Did a full sweep of the Heltec V4’s actual conducted TX output power using a spectrum analyzer. Turns out the GC1109 PA tops out around +27-28 dBm - settings above TX=18-20 give you zero extra power, just extra battery drain.
Quick summary:
TX=5 → +12.2 dBm (17 mW) - close to EU 868 MHz legal limit
TX=10 → +20.3 dBm (107 mW) - already over 25 mW ERP with any antenna
TX=20 → +27.7 dBm (593 mW) - hardware maximum
TX=22 and TX=24 → same as TX=18, PA is saturated
If you’re running solar/battery repeaters, this matters a lot - TX=5 vs TX=20 is a 35x power difference for the radio.
Full methodology and data table: Heltec V4: Measured TX Power Output Table (firmware setting vs actual conducted dBm) · Issue #1708 · meshcore-dev/MeshCore · GitHub
Also cross-posted to Meshtastic #8070 since it’s the same hardware.
Serge
