MeshCore App v1.16.0
Hier für Android herunter laden, oder in 1-2 Tage auch via Android / iOS App Store:
  • this is the first release that also includes a web.zip so you can self host the web app!
  • added ability to set contacts as favourites
  • added ability to filter contacts by favourites only
  • added ability to view own telemetry from settings screen
  • added new “heard x repeats” to channel messages when a repeat is heard by your companion radio
  • added view telemetry button to contact details screen for repeaters
  • added contact avatar to contact messages app bar and improved app bar text
  • added repeater clock from login response to the repeater status page
  • added support for new noise floor stats for repeaters and room servers
  • added distance between hops to info popup when tapping snr bubble in map path trace tool
  • added dynamic contact avatars to discover list
  • improved error message popup when clock cannot go backwards,
  • max channel message length is now calculated based on your device name
  • simplified user experience for filtering contacts
  • fixed bug where info banner on connect screen would show up as you went to tap screen
  • fixed bug where you could enter more text in device name field than firmware would accept
  • fixed bug where sending long channel messages would cut them shorter on recipient side
