Added new total rx airtime info to repeater stats
Added info about sender and receiver to advert path viewer
Added support for new multi acks in message settings screen
Added button to show labels for markers on map trace tool
Added ability to choose radio preset for repeaters, room servers and sensors via remote management
Radio settings dropdown has been replaced with a choose preset button
If public channel exists it’s now always shown at the top of channels list
Custom channels now show a lock icon to indicate that they are private channels
Chat contacts are no longer counted for ping warning when multiple contacts have same first byte
Previous database is loaded when relaunching app so you can now see message history without connecting to node
Importing contacts now uses last modified timestamp from imported config file instead of current timestamp
Improved ui of map marker labels
Fixed bug where importing contacts list would fail if your companion was in the list
Fixed bug where contacts limit in settings would show negative number when limit higher than 127
Fixed bug where system font scaling would break map marker labels
