- Added seconds to rxlog timestamps
- Added ability to manage repeater regions via remote management
- Added ability to discover regions from nearby repeaters in select region menu
- Added ability to dismiss repeater region info banner on channel messages screen
- Added ability to change repeater identity keys and choose new prefix via remote management
- Added new received packet errors field to repeater status screen
- Added experimental setting to use companion clock for packet timestamps
- Coverage tool now tells you if there is no elevation data for selected point
- Hashtag symbol is no longer required when adding region scopes
- tx power is now read as signed int as new firmware will allow negative tx power
- App will now only process v1 packets in preparation for new v2 packet formats
