- added support for new companion repeat mode (requires companion firmware v1.13.0+)
- added new messages setting to jump to the oldest unread message when opening a conversation
- added new messages setting to keep the screen on while viewing a conversation
- added support for multi-byte path segments in path trace tools (all repeaters must be on firmware v1.11.0+)
- added dropdown menu button to manual trace tool to auto add return path
- added red info text to manual trace list if multiple repeaters are known for hop
- added button to save regions via remote management
- added info banner to repeater region management when there are unsaved changes
- added new long press menu to local and internet map screen
- added 1 second delay after sending message before allowing another message to send
- connect screen tabs now default to showing last used connection type
- removed connection options dropdown menu from connect screen (use the tabs instead)
- repeater region management ui now shows error when failing to fetch list
- direct messages now have additional random delay between retry attempts
- fixed bug where popup menus were light themed in dark mode
- fixed bug where rx log wasn’t parsing advert feature flags
