MeshCore App v1.42.0 ![]()
- v1.42.0
- added ability to long press ping buttons to use multibyte ping
- added ability to open line of sight tool from coverage map tool menu
- added ability to import and export discovered contacts as json from discover screen menu
- added menu buttons to select all and deselect all contacts while in multi select mode
- added radio checkbox to select region screen to make it more apparent you must select the region to use
- added translations for dutch, french, hungarian, italian, polish and slovak
- antenna coverage tool now automatically fits map to imported json layers
- spaces are now allowed and automatically trimmed from path field in manual trace tool
- improved error message when unable to share contact to internet map due to missing advert blob
- channel messages must now be 10 bytes shorter if a region scope is applied
- fixed bug where contacts full notification would show even when preference was turned off
- fixed bug where adding contacts from discover wouldn’t copy over the last advert timestamp
- fixed bug where it wasn’t possible to swipe back to exit discover screen on ios
