MeshCore App v1.44.0 ![]()
Change Log:
- Added support for usb connections on windows, macos and linux
- Added checkbox to allow auto reconnect on wifi connections
- Added ability to send unscoped channel messages when default scope configured (required firmware v1.16.0+)
- Added auto link support in chat messages for latitude,longitude with at least 3 decimals
- Added snr signal strength support for sf5 and sf6
- Added language translations for spanish and romanian
- Redesigned message composer ui with ability to share contacts and positions
- Typing @username in channel messages now auto adds a space afterwards
- Repeater neighbours list can now resolve names from discovered contacts database
- Repeater neighbours can now show on map tab even if the repeater youโre logged into has no position
- User is no longer forced to change frequency if itโs already allowed when turning on repeat mode
- Draft messages are now saved by default this can be turned off in message settings
- Improved pairing flow for bluetooth companions on windows
- Fixed bug where some commands would not time out
- Fixed bug where connect screen would not close when node auto reconnected
- Fixed bug where deleting an outgoing message would keep retrying even if delivered
